Swinnys 4 Place Bush Explorer
BushCaddy L164
Fitting rear spar to wing ribs
Today I removed the rear spar once again so that I could solid rivet (using the rivet squeezers), the rib attach angles to the ribs after I had finished deburring and priming.
Typical angle attachment between rib & spar
BushCaddy L164 Home
3616
A/Filter & Snorkle
Ailerons
Brake systems
Cabin
53
372
Cowls
Doors & Windows
Elevators
Engine Baffles
Engine mount
External lighting &
Fairings
Final Assembly & Ins
Firewall fittings
First Flight & Tests
Flaps
Flaps
Getting sidetracked!
Horizontal Stab.
Instrument panel
Interior Lighting
Internal linings
Kit delivery
Paint Shop
Prop & Spinner
Seat Belts
Seating
Static System
The A P Inspections.
Undercarriage
V-Stab
Vert-Stab
Wind Screen
545
Wiring
