Swinnys 4 Place Bush Explorer
Date:  6-27-2013
Number of Hours:  8.00
Brief Description:  Riveting Spar backing plates
Slowly getting back into the swing of the building process.
Finished setting the 5/32 rivets through the re-inforcing plates & then repositioned the spar back to the ribs and made up the 3/4 X 3/4 X 1/16 6061 attaching angles for the ribs that had to be cut back due to the added thickness in the spar.
5/32 Solid rivets set
Rear left wing spar back in place.
Attaching the cut back ribs.
