Stevens Web Site
Date:  6-17-2005
Number of Hours:  1.20
Brief Description:  Build jig for C-Frame dimpler
Using a scrap sheet of 3/4 inch plywood, I cut a support structure to surround the c-frame dimple die. I cut the sheet in half and then glued the two halves together. I then cut out a slot for the foot of the c-frame dimpler. It will fit around the dimpler. I will put the plastic grass door mats around it to support the last 7/8ths of an inch of depth and to prevent scratching. It should be easier to shake out aluminum shards from the door mat than from carpet.
C-Frame with plywood base
Plastic grass cushion
C-Frame dimpler ready for action
