My RV-8 Build Log
RV-8
Prepping the HS for Prime
The HS (and the VS) are looking a little worse for the wear after 7 years of construction. Started sanding the skin with fine scotch brite to remove some scratches and prep for prime and eventually paint. Sure looks and feels a lot better.
HS Prep with Fine Scotch Brite
RV-8 Home
2687
Ailerons and Flaps
Baggage Door
Brake System
Cabin
Cowl
DAR Inspection
275
342
322
Fairings
54
153
First Flight
Flight Control
Flight Training
Instrument Panel
Lighting
Markings, Placards a
Paint and Prep
Phase I
Pitot/AOA
Post DAR Inspection
QB Kit
Static Pressure Syst
Tech Councilor Visit
Tech Inspection
Tires
Transition Training
Weight and Balance
Windscreen
