Brief Description: Emp Fiberglass Work Continued..
More filling and sanding of the elevator fiberglass fairings. While the epoxy/microballons set up, started working on the HS fiberglass fairings where the fairing covers the leading edge of the elevator counterbalance weight. A balsa block is used to provide backing got adding the epoxy and microballons mixture.
