After completing the exhaust opening in the lower cowl area, I then moved up to the left top opening cowl. I again used the stiff card board as a template, then transferred this onto the aluminium.
These cowls will need to be put through a set of rollers to form the curve as there is too much pressure required to hold them in position.
I will track down a set of rollers when I doo the other side.
