I've decided to put access holes in the top skin. I'm just worried someday I or somebody will need to access the avionics bay and working from underneath won't work. I tried it this week and the wing spar is right in the middle of your back. Really hurts. Someone someday will be glad these access panels are there.
Turns out you can buy precut access panels so that all you have to cut is the one main hole in the skin. So I did. The cut lines are nice and perfect.
And the first hole seems good. Lots of work to make straight lines and rounded corners.
