Removed the peel ply from the splice ply layup. Sanded down the high spots with 80 grit.
Removed the (now one piece) skirt from the canopy frame and laid it on the table upside down. Removed the remaining clay from the IML side of the rear splice. Sanded and cleaned the IML side of the splice.
Cut and wet out a four ply tapered prepreg skin to bond on the IML side of the rear canopy splice to add strength. Brushed some epoxy on the IML side of the splice and placed the prepreg layup on the splice. Applied peel ply and let the epoxy cure.
