N983LK
RV-8
Prep for wing installation
Hooked up the rudder cables and installed cotter pins
Replaced desiccant in the clyinder plugs
Leveled the fuselage in preparation for installing the wings
Chamfered the edges the root end of the spars
Removed the bolts and spacers from the spar carry through
Made 4 drift pins from 7/16" bolts.
Tightened the lock nuts on the pitch trun push rod. Installed a cotter pin,
Pitch trim linkage
Cotter pin in rudder bolt
Drift pins for wing installation
RV-8 Home
4531
428
Baffles
43
189
276
Cowl
285
418
199
Flight Testing
1522
Prep for flight
Shop Setup
958
