Spray 2 coats of primer on spots that received new body work. Gun settingss as follows: HVLP spray gun. 30 psi, 4:1:1 ratio of primer, activater, and reducer. Once it cured, about an hour and a half, I sanded with 220 grit on the DA sander and then hand sanded with 400.
