Finish hand sanding primer on bottom of fuselage with 400 grit. Wash belly, rinse, dry. PrepAll, tack, and drape.
After sanding there were a few spots that were still high. The sanding went through the latest primer coats, so I'll just prime them again instead of the entire bottom. I taped and draped the fuse in preparation for the next coat of primer.
I also draped and taped the outside of the canopy (pic 2 background) and finsihed the touch up work on the elevators. I'll prime them when I apply primer to the fuse spots. The fuselage is getting pretty close.
