Frank's Panther Cave
Date:  1-4-2017
Number of Hours:  8.00
Brief Description:  Spar Drilling
Left spar marked up with correct harware for each hole.
The drill press was set up on the table and spar levelled, each hole was drilled out with #10 drill for rivets and 3/16" ready for reaming for tight fit of AN harware.
Correct holes countersunk to match rivets and bolts.
Clear marking - a mistake is costly
Drill press for nice square holes
Check countersink depth
