Quadrant was incorrectly purchased as a reversing type, this will be modified to suit normal operation. Hole drilled in top to suit travel requirement for Jabiru engine and sample cable used for setup.
Trim cable mounted and cable terminator drilled into map pocket.
Aluminium bracket fabricated to mount rudder cable guide to fit across throttle quadrant.
