Finished attaching the top fabric on the right wing, then heat shrunk to 250 degrees. Before closing I installed the two fabric attachment plates at the strut attachment locations. I then finished the fabrication of the magnetometer mount and sanded it down. I then heat smoothed some of the leading and trailing edges. Also drilled stitch holes for the rib next to the tank.
