ROBERT'S WEB SITE
Date:  2-23-2018
Number of Hours:  5.00
Brief Description:  Magnetometer And Bottom
Ran the wiring for the Dynon Magnetometer out to the wingtip and used wire ties to hold it through the center of the wing. The wiring needs to stay away from the light wires due to sensitivity of the magnetometer. I then went to work on my own design for the mount. It will have two dowel rods that I can insert into drilled holes in wood hysoled to the last two ribs. I will be able to remove it with two non magnetic screws at the tip. I then sanded and put on two coats of polybrush on the wing. I manged to get the bottom covering installed and flipped the wing over for the top next. Seemed to be more wrinkles on this one, but the iron got rid of them.
