Canopy frame was secured with hinge pins and locked with 3/8" tube. The outside canopy was then marked and drilled for the side rivets. The canopy was marked and trimmed at the hinge line to allow the 90 degree rotaion.
Side strengthers were bent and match drilled to frame.
Clearance hole was cut with 2.5" hole saw to clear roll cage.
