Frank's Panther Cave
Panther LSA
Rib 1
Time to use the dreaded Pro-Seal stuff for the first time.
All parts deburred and cleaned with acetone the required rivets also soaked in acetone and left to dry.
Mixed 35 grams of Proseal for each rib and tried to keep everything clean, but it is very difficult and probably used too much sealant in the end.
Maybe it gets better the more you use the stuff...and it probably wont leak..
End result - 2 ribs sealed
Corby Starlet Home
Panther LSA Home
1991
Fuel Tanks
Spar
Tailcone
