Finalized the coolant overflow today, that entailed moving the fuel supply lines and some other small stuff. It is getting tight to fit stuff in, sure will be happyt to see the ECU come back, that placement alone has 6 other items held up for mounting and hooking up hoses and wires. I plan to make a door in the panel thru which I can put a memory stick for ECU upgrades and software information.
