The further you get, the more you have to go thru a thought process to make things fit! I had left the overflow bottle for the coolant delay as long as I could, but decided that this one would maybe work. All it took was to shorten the fuel rail a bit to make room, and finally it would go in nicely in a space not yet used. I am happy with the final product (as soon as it is final, still got to make a couple of holes for the tank brackets and bolt it on). The first photo is pretty well where and how it will fit, the second shows how much to cut off, and the third was an earlier attempt to fit it that I discarded.
