Frank's Panther Cave
Date:  4-4-2014
Brief Description:  Horizontal Stabiliser
Mounted and trued up the diagonals of the horizontal skeleton by cleko the ribs to the spar. When happy with the squareness of the frame time to screw down to the timber. Skins slide under the frame and start with fitting to the top by match drilling. Start from the rear and clamp the skin on the forward spar, match drill from the centre out to the leading edge.
Top drilled and frame rotated
Ribs only clekoed at this time
