Frank's Panther Cave
Panther LSA
Vertical Stabiliser
Fitted the closer rib and adjusted for best fit. Drilled and cleko to top rib.
Fitted fibreglass tip and drilled initial hole. Used fan spacer to mark all the additional holes and drilled out to #40.
Cut two strips of 0.20" aluminium and glued into position of fibreglass tip. Use Tarzans Grip glue, bond worked out well after 10 hours dry time.
Mark out and drill #40 holes
Aluminium stiffener on inside of fibreglass
Corby Starlet Home
Panther LSA Home
1991
Fuel Tanks
Spar
Tailcone
