Formed the crankcase breather line from the air/oil separator outlet to below the firewall. The breather line is from 5/8" aluminum tube. The line follows the side of the fuselage on the right side and exits out the bottom. Used two clamps and two 10x23 flat head screws to secure the line to the side of the fuselage.
Connected the ground wire to the fuel pump relay terminal 31. Need to test the fuel pump relay operation when the engine is running.
Breather line connection at air/oil separator outlet
