Cut the cable outer shield and inner wire to length. Fit the wire end clamp and ball joint end to the mixture control arm. Attached the wire end to the end clamp and mixture arm. Measured for a bracket to secure the end of the bowden cable outer shield. Fabricated the bracket and riveted it to the bottom of the air box. Clamped the bowden cable shield end to the bracket. Tested the mixture control. Put label on the cockpit mixture control knob.
Mixture control cable through the firewall and outer shield end clamp
Mixture cable ball end fitting and wire end clamp fitting
