Fabricated fuel pump and sensor cover. I made two. One from 26 ga, 0.018", galvanized sheet metal and another made from 0.025" aluminum sheet. I did not use the galvanized sheet metal cover because I judged it to be too heavy at 1.5 lbs. The sheet aluminum cover weighed 10 oz. The sheet aluminum cover will be covered with heat shielding material to protect it up to 1000 F.
