Louies Web Site
Date:  1-5-2012
Number of Hours:  3.40
Brief Description:  Wiring
Continued with wiring the ignition system. Measured for the shield that will need to be fabricated to cover the fuel pumps, filter, and associated fuel system on the frewall. The shield will permit cooling air to flow over these components to reduce fuel vapor lock on hot temperatures. Went to town and bought 2'x4' piece of 26 ga galvinized sheet steel for the shield. Bolted the motor mount to the airframe and set the motor on the motor mount on the urethane cushions. Temporarily put bolts through the mount an dmotor basae for security. Checked fit of some of teh exhaust pipe attaching pieces.
