The epoxy still was gummy on the surface and couldn't be sanded. I scraped the epoxy off using a sharp wood chisel and piece of thin steel. Then, I sanded the surface beginning with 80 grit paper until most of the epoxy was removed. Further sanding with 150 grit smoothed the surface more.
