The epoxy on the turtleback did not cure properly. It is gummy on the surface. I elevated the temperature inside the turtleback so the outer surface was about 135 F in the hope that would cure the epoxy. Then I let it cool. Shop temp was about 65 and epoxy spilled on the floor cured fine.
