Completed network cable installation between the ADAHRS unit and the Skyview unit. Installed the static ports in the fuselage sides behind the wing. Routed the static line tubing from the ports to the ADAHRS static port and on forward to the area of the analog airspeed and altimeter gauges in the instrument panel. Did not terminate that end of the static line. Used the pitot-static-angle of attack kit from SafeAir1. www.safeair1.com
