Ran the cables from the OAT to the ADAHRS. Had to cut about 30 inches out of the cable for correct length. Put the plug on the cable end. Ran the cable from the Dynon Skyview unit to the ADAHRS. Put two 3/4" grommets in the frame behind the seat and the vertical frame at the rear spar. The cable was 6 feet too long. A section was cut out with the ends spliced together. Inserted the female ends into the 9 pin socket and installed the socket cover.
