Riveted on the small left and right clips to the sub-panels—these clips tie the sub-panels to the fuselage sides. Next, I drilled out the two rivets that were sitting slightly proud, cleaned up the holes and squeezed in a couple of new rivets. Installed the instrument panel and sub-panel assembly into the fuselage. Began reviewing the drawings for the baggage door and front top skin.
