8-20-2012 |
4.00 |
Riveting begins! |
Time to rivet the vertical stab trailing edge spar and stiffener. All primed and cleco'd together, Lets set up and get with the program! I used the pneumatic squeezer mounted to the table for this operation. Mounting the squeezer to the table takes the guess work out of setting the AN470-6 and -7 rivets. Perfect every time...Well, almost..... There was one that had to be drilled out..... |
