5-26-2012 |
2.00 |
Labels, engine alignment |
Applied several more labels including: - Two Jet-A / usable fuel labels - HOT warning label near engine - Two oil filter part number labels - Tail gearbox oil type label - Fragile label on throttle arm - No Push label on door sills Lowered the rear engine mounts 1 turn to re-align the pulleys after having added a turn to the clutch clevis a couple weeks ago to bring the clutch pull up to 45 lbs from 35 lbs. |
