Date:    4-24-2012
Number of Hours:    1.00
Brief Description:    Heat shield
Began fabrication of the exhaust heat shield using the cardboard template I made yesterday to cut the shield from .032 aluminum, radius-ed the corners and smoothed the edges on the bench sander. Engine turned both sides of the sheet before bending the angle into it to make it easier.
