4-15-2012 |
2.00 |
Blade supports |
Went back out after supper and mostly finished the rear blade support. Riveted the two angle pieces to the bottom of the cradle. Bolted on the channel piece. Cut two 35" pieces of conduit, drilled and bolted the conduit to the cradle. All that remains is flattening the bottom end of the tubes and drilling the holes so it can be bolted to the frame. |
