Date:    2-29-2012
Number of Hours:    1.00
Brief Description:    Rotor head, pitch block
Made a V block clamp to grip the main shaft so I can set the rotor head on it while I get things lines up and pinned.
Tried out the blade pitch block I made a few days ago. Comparing the reading on the pitch block to the grip block shows a difference of only .1 degree.
The original owner had started cutting out a blade tip plug but the wood split at the thin trailing edge. I will use this first attempt as a template to make the two tip plugs.
