Date:    2-13-2012
Number of Hours:    2.00
Brief Description:    Vertical fin, LED strobes
Soaked the vertical fin end plugs with CA glue to seal them before painting then final sanded.
Drilled holes in the sides of the pod behind the LED strobes for the wires. Installed rubber grommets, routed the wires inside, connected and secured them.
