Date:    1-25-2012
Number of Hours:    2.00
Brief Description:    Capacitor
Received the large capacitor from Digi-Key today so I decided on the mounting location inside the pod, cut the wires to length that I had previously installed and installed the ring terminals.
Tested the operation of the capacitor and found that it will only power the fuel flow meter for about 2 seconds once the main power is cut but the engine tach stays on much longer.
Started looking at possible routing and locations for the radio antenna.
