Date:    1-1-2012
Number of Hours:    5.00
Brief Description:    Wiring, labels, routing, bundling
Temporarily attached the lower panel to check clearance and plan out wire routing.
Spent a lot of time organizing, routing and securing the left side wire bundle and clutch switch wires.
Used a label maker to make up wire labels, red labels for wires connected to +12v, black labels for wires running to ground and white for gauges and others. Verified wire destinations with an ohm meter and applied labels.
