Date:    12-30-2011
Number of Hours:    8.00
Brief Description:    More wiring
Finalized left side wiring up to the cabin and final mounted the governor. Fabricated an aluminum strap that attaches to the back of the governor to hold the wires down and prevent them flexing at the connectors.
Soldered leads to the fuel pump and routed to the panel area and connected the ground lead to the terminal strip.
Ran three additional 12 awg wires down the right side, two for +12v from the main cut off switch to the panel and one from the regulator to the panel.
Still need to route the exhaust temp wires down the right side to the panel, then all the wires should be in place except for inside the pod itself.
