12-27-2011 |
1.50 |
Left side wiring |
Started working on the left side wiring which includes: Transmission temp probe Clutch position switch Clutch actuator Rotor RPM Engine oil temp Engine oil pressure sender Engine oil pressure warning light switch Hour meter (oil pressure/clutch engaged) Main Fuel Solenoid Governor main power Governor backup power Engine RPM pickup Throttle potentiometer to governor |
