9-27-2011 |
3.00 |
Battery power straps |
Fabricated four 90 degree, copper straps (3/16" thick by 1" wide) to allow the battery wires to be attached on the side of the battery for a cleaner install that also allows the wires to be better secured against vibration fatigue. Tapped two 10-32 holes in each strap for attaching ring terminals, bent the straps to 90 degrees on a brake at work, and drilled a 6mm hole for the battery post bolt. |
