Date:    9-21-2011
Number of Hours:    2.50
Brief Description:    Safety wiring, Battery boxes
Safety wired the exhaust temp probe, the exhaust pipe clamp and the burner can clamp.
Installed the right side battery box on the frame then bent the hold down strap to fit and cut to length and mounted the box. Also made up the strap for the left side box which I'll mount tomorrow.
Installed the main cut off switch in the tab on the front side of the right battery box.
