Date:    8-26-2011
Number of Hours:    3.00
Brief Description:    Governor box, engine mounts
Used low temp aluminum welding rod to flow into the lower corners of the governor box to fill the last little bit of the joint where the TIG couldn't reach in an attempt to make the box as RF tight as possible.
Prick punched the three engine mount clamps that come in matched, machined sets so I can keep them together. Cleaned up and jeweled all the aluminum engine mount parts.
