8-9-2011 |
2.00 |
Clutch actuator |
Test fit actuator to the frame and ground bevels on the corners of the actuator shuttle so it will fit into its attachment on the clutch arm. Tested the travel on the clutch arm and found that the actuator lacks about 1/4" of reaching its stop when the clutch is fully engaged so I will need to modify the stop location or alter the lower mounting hole location. Determined the location for the micro switch on the mounting plate I made earlier today so I can finalize its shape and switch mounting hole locations. |
