3-8-2011 |
2.00 |
Fuel system leak test |
Installed Tee and fuel feed lines between the bottom tanks then connected the Tee to a temporary line and valve to close the system and provide a way to drain the tanks after the leak test. Filled tanks with 18 gallons of gasoline, no leaks detected, left the fuel in the tanks for now. |
