2-12-2011 |
3.00 |
Upper tank |
Installed upper fuel tank. Used ratchet strap to pull it tight into position so the mounting holes aligned with the tabs on the frame. Had to bend a couple of the tabs in slightly toward the tank. Installed the two small plates under the tank that spread the load where the tank sits on the frame tubes. |
