Date:    1-31-2011
Number of Hours:    3.00
Brief Description:    Half Doors
Drilled and tapped screw holes in the three door latches. Turned down latch pins for the door latches. Started turning the pull knobs that will attach to the latch pins.
Cut excess material from the fiberglass door frames using the band saw.
