1-8-2011 |
5.00 |
Pod brackets, seatpan removal |
Located and drilled front pod to seatpan bracket, installed nut plates, drilled and counter sunk backing plate. Removed instrument pod. Drilled rear pod to seatpan bracket for five 1/8" rivets. Adjusted two frame tabs under right side of seatpan so they sit against the fiberglass without pulling when the bolts are tightened. Removed seatpan from frame. |
