Date:    8-7-2018
Number of Hours:    3.00
Brief Description:    started left wing lighting
I wanted to catch the left wing up to the right. Used the same process as before to cut hole in wing tip. Dremel and cutoff wheel, a sanding drum on angle grinder then a file to smooth. The hole turn out fine glad to have that over. I cut and fit the plexiglass lens and completed the wiring for left landing light.
