3-18-2019 |
2.00 |
Remove elevators from assembly for repair Assembl |
After reading up on the control stick assembly I realized I needed to take more time to confirm that the sticks were aligned and parallel. I set the assembly on the bench leveled the assembly and set a square on the forward control stick, adjusting the rear control stick until it was perfectly square to the assembly/push-rod. Removed both left and right elevators from the horizontal stab and took them to work for repairs |
